I’m having consistent issues with PDF export, where one or more elements is missing from exported PDFs. The missing elements are sometimes vector objects created in Figma, and sometimes raster images imported into Figma. I always confirm the elements are correctly inside the desired frame before PDF export. Are there any known issues that prevent PDFs from rendering correctly?
PDF Export Consistently Missing Elements
Best answer by Daphney_Dupervil
So I found a workaround to the missing elements issue when you export your Figma design to PDF.
Add a section behind the designs you want captured. You can access sections:
- Region Tools
- Select - Section (Shift + S)
Then add the section behind the design(s) you want to capture. Once you do this - it should appear on the PDF when you export it.
Happy designing!
