Morph from circle to rectangle
  • August 23, 2022
  • 8 replies
  • 3603 views
Roman58
Hi guys,
I am trying to make a circular button which expands and morphs into a rectangular drop-down menu.
I made a simple rect with round corners and, from its copy, made a circular button.
But when using Smart Animate, it morphs into an oval.
Is there a workaround?
Roman58
  • August 24, 2022
I have done further tests and it seems only a problem with strokes. When shape has only fill it works.
@Figma_Support is it a bug or limitation ?
MattyH
  • August 24, 2022
Hey Roman!
What might help here is a small storyboard of the animation you’re trying to achieve. From your description maybe breaking it up into 3 or 4 static design versions of each stage of the animation should do.
From there, it might be easier to help identify the right way to animate it 🙂
Matty
Roman58
  • August 24, 2022
Thank you, I thought about it as well. But have not tried. Was trying keep frames to minimum
MattyH
  • August 24, 2022
Sure, these could be temporary just to understand the animation 🙂
Roman58
  • August 24, 2022
Animation is simple and basic, it just a scale in one axis 🙂 but for some reason doesn’t work with strokes
MattyH
  • August 24, 2022
Ran the same test myself and getting the same result as your video…
Just also did a bit of searching around and it looks like you’re definitely the only one! Looks like it’s not yet supported. Smart animate for frame with stroke glitching - #3 by Keith_Vaz
Roman58
  • August 24, 2022
Cool. Thank you. Hope Figma guys will fix it
  • September 23, 2022
