Modal auto layout
Kublaiboy
Hi,
I’m trying to make a simple modal with auto layout. I started with the title “Submit your contact info”. I added Auto Layout(AL) to the title. Then added a white fill around the text. That turns into a modal box. I set AL to be vertical(↓), so I can add more input fields and a button. The modal will AL the height. Now I want to add a close icon X. That’s where I got stuck. This X needs to be anchored to the upper right corner. If I simply drag the X icon in the modal, it gets aligned to the left side as the rest of the input fields. I want the modal to be stretchable. So when you change the width of the modal, the input fields and button widens. I just couldn’t figure out how to set it up. The closest I’ve gotten is to create another AL around the X. Set this AL to be horizontal (→). This pushes the X to the right. But now the X is above the main title. It still doesn’t look right. And when I resize the modal, the input fields don’t stretch(narrows or widens).
Pleas help. Thanks.
Screen Shot 2022-04-18 at 7.53.49 PM
Screen Shot 2022-04-18 at 7.53.59 PM
Screen Shot 2022-04-18 at 7.54.06 PM
Best answer by AzanAF
On the right side of your screen on the ‘Design’ pane, you will find options labelled ‘Constraints and resizing’. You would want all the elements inside the auto-layout modal to ‘Fill Container’ instead of being ‘Fixed Width’.
AzanAF
  • April 19, 2022
Kublaiboy
Thanks. I found that you could do the nested auto layout for more complex responsive layout. I think I was having trouble to figure that out. Once I tried nesting, it all make sense now.
Mikael_Cederbom
I highly recommend to check out this official Figma file:
Figma
