Is there a way to prototype swipe left to delete?
george_ramirez
im doing a prototype for a new feature in stitch fix as part of a class project. i’d like to build a prototype where user SWIPE LEFT to delete items and SWIPE RIGHT to add an item. is there a way to do this? 😦 i need to figure this out in the next week, aaargh.
thks so much anyone out there that has an idea of how to do it if IT IS possible.
Best answer by ntfromchicago
So when you swipe left or right, do you mean:
a) Swipe and the product tile moves off the screen
b) Swipe and the tile stays in place but shows something new
Both are possible but a) would be quite difficult/challenging to set up if you were going to try and demo all the tiles. If just one or two as an example, maybe a little easier.
b) is definitely doable. If you have access to the interactive components beta, definitely much easier.
LMK if that helps you at all or not.
K.ian
  • 27 replies
  • April 14, 2021
As far as I know, no, there is not. The closest thing I could think of would be to use an overlay.
Good luck with your class project!
ntfromchicago
  • 287 replies
  • April 15, 2021
george_ramirez
gotcha! actually just 2 tiles and that they dissappear would be great 👍
ntfromchicago
Figma – 21 Apr 21
Since it’s just two tiles (and I presume you can choose which two to do) you can use the drag trigger with a magic animation transition to simulate the use case you’re going for. Best of luck!
