Is there a "find and replace" or a plugin for locating where a color style is being used?
  • January 4, 2022
  • 4095 views
Kat
I have two libraries (iOS and Android) that share some identical color styles but want to keep them agnostic of each other. The problem arises when I update one (e.g. iOS/text_white) and open the other library and get a “Review changes” prompt which tells me that the iOS/text_white color I just updated is mistakenly being used somewhere in my Android library.
Does anyone have any methods or a plugin that would help locate where that rogue style is being used? Something akin to a find and replace but for color styles?
  • 4845 replies
  • January 4, 2022
Hey Kat,
There should be a plugin that does this. Here’s an example:
Figma
In the future, you can search directly in the community for any type of plugin you’re looking for.
Kat
  • January 4, 2022
Thanks for the response! This isn’t quite what I’m looking for as I’m looking for more of a “locate color style” as opposed to just “locate color”.
To clarify in a more concrete example, I might have two libraries (iOS and Android) that both have “text.main” as a color style, both using #000 as the hex code.
Occasionally, a rogue component in the iOS library might accidentally be using the Android “text.main” color style. This might not seem like a big deal as they initially are both mapped to use #000, but if somewhere down the line we were to change “text.main” in the Android library to #333, it would be an issue if a component in the iOS library was accidentally using the Android “text.main” as it would then be using #333 as opposed to #000.
So what I would need is a plugin or some feature that would allow me to search a file (or even a page) to find everything using “text.main” so I could check each one to make sure it was using the correct one (either iOS or Android.) Alternatively, being able to identify anything using a style from a different library would also do the trick.
I’ve searched the community page and couldn’t quite find what I was looking for so I decided to drop it in the forum in case I wasn’t using the right search parameters and missed it.
  • February 3, 2022
