Images inside the frame not visible in Presentation mode?
Krish1
I added an Image in Drafts. Then I put a frame around it. I also made sure to move the image to the front so the image is visible. When I clicked on “play” button to present, the frame shows up, but the image does not. What am I doing wrong?
Best answer by tank666
The “image 2” layer should not be above, but inside the “Frame 3” layer.
Open the layers panel on the left to see this (Menu ⟩ View ⟩ Panels ⟩ Show left sidebar).
tank666
Could you show a screenshot of the layers panel or send a link to the file?
Krish1
  • June 10, 2021
Here it is: https://www.figma.com/file/CbaTfI2iKKxXE71wf0dZcc/Untitled?node-id=0%3A1
It is in drafts mode and if you cannot see the layers panel, then here are individual screenshots:
tank666
Krish1
  • June 11, 2021
Thank you so much. That worked!
