How to edit a component that has lots of variables
  • October 21, 2022
  • 8 replies
  • 1345 views
Noah7
Sorry if this is a noob-like question.
I’m trying to edit a Form UI Kit, it is made up of components and each component has lots and lots of variables.
I would like to change the look of all the variables inside the component but I’d rather not go through each variable individually. Is it possible to edit the original component so that it updates all the variables at once? Like, say changing rounded corners to sharp-edged corners.
Thanks
  • October 21, 2022
When you edit the main component, all its instances (that are presumably used within the form) will be updated accordingly.
Noah7
  • October 21, 2022
The main component is made up of all the variables. If you look at https://www.figma.com/community/file/1148375559326132425 - Main Components - Forms and Inputs - Input
Noah7
  • October 21, 2022
This is the UI Kit I’m trying to edit “Essential Forms & Controls UI Kit” If you clone it and then look at - Main Components - Forms - Input. You will see what I mean. Input is the component and that is represented by a big dashed line that goes around all the variations of the forms/variables. As far as I can see there’s no way to edit one to edit them all?
Thanks
SohrabNiroo
  • October 28, 2022
Yes you can
  1. Select the first variable layer you want to edit and do the Edit, then Copy ( Ctrl + C )
  2. Now make sure you’re in the Design tab on the right panel
  3. Then select the 2nd variable layer that you edited in the first and want to make the changes happen to it.
  4. You must be able to see an icon under your selection like Target ( or aim Gun ) 😃
  5. hit it and all the same layers in different variables will be selected, If you want to deselect some Hold shift and deselect wanted layer
  6. Now just hit ( Ctrl + Shift + R ) or right click and choose Paste to Replace
The edited layer will replace with the chosen layers
Noah7
  • November 2, 2022
Thanks for your response but the problem is that I can’t edit any variable.
I click on a variable, say “Main Components” - “Outline, 1, Text, Default, None, Icon=No, Helper=No” - Then I click on the - “Label” layer and try to move it, it then breaks outside the variable and jumps to the top of all the layers?
Noah7
  • November 2, 2022
… OK I figured it out, so simple when you know how. I just copy components to my project and edit them in there 😮
SohrabNiroo
  • November 3, 2022
Your welcome, Just wanted to say what to do then I saw you handled it yourself.
Best Luck!
  • November 20, 2022
This topic was automatically closed after 30 days. New replies are no longer allowed.
