Figma to PDF -- readable by resume scanner software?
  • January 8, 2022
  • 8 replies
  • 9670 views
David10
Hello world,
I made my resume on Figma. When I export as PDF and then open in Adobe Acrobat Reader, I can’t properly highlight text. I try to copy and paste from it and I notice that it pastes as a string of garbage. Does this mean that my resume will have problems being read by employers’ resume-scanning software?
Brandon6
  • January 12, 2022
Yes, that is correct – the exported PDF will be unreadable by ATS software 😕
I’m also looking for a solution to this because I’d love to keep my resume in Figma, but it’s not currently a viable option.
David10
  • 5 replies
  • January 12, 2022
Thanks for confirming @Brandon6. Such a bummer. I really wish I had considered this before I so painstakingly designed the thing in Figma…even set it up with “components” and “auto-layout” for quick updating later. Thought I was so clever. 😑
Brandon6
  • January 13, 2022
Yep, I also discovered this in hindsight, lol
I’m going to explore a few plugins to see if any that offer expanded PDF export options might help.
MayZ
  • January 14, 2022
I use Figma for my resume as well but I have no issue with highlighting my text when I export it as PDF. I don’t do anything special for it either, I do use a plugin called Tinyiamge Compressor to keep the file size small.
David10
  • 5 replies
  • January 14, 2022
Hi @MayZ , I’m able to highlight. But when I copy and paste it comes out corrupted. Example: †$€#‹#A#e!ƒ†A „† eA‹"$vve!
And when I opened the file in TextEdit, I also observed there that the text strings were corrupted.
Can you run this test with your resume? Are you sure the text comes through in a readable format? I’m not familiar with the Tinyimage Compressor plugin but I wonder if that is a true workaround…
David10
  • 5 replies
  • January 14, 2022
Please report back if you find something!
MayZ
  • January 14, 2022
Oof I just did a quick test with two PDF files exported from Figma:
  1. Direct export without the plugin, you were right, I do see strings of garbage when I copy and paste the text.
  2. Export through Tinyimage Compressor, I am able to copy-paste the text (the bullet points show up as a box), however, I do notice sometimes the last letter in the sentence shows up as some weird symbol too…
  • February 13, 2022
