Figma doesn't update variant overrides in prototype
Felix_Montana
Hi guys,
I have always had problems with updating the overrides in Figma since I have a master component with two variants and a microinteraction in them, I use this component in a frame and I changed overrides but when I see the prototype it does not update the overrides but leaves the texts by default .
I have tried using texts with the default layer name (which changes as you type) or resetting it to a defined value but neither option works
Any help to avoid having to create several frames? or am I making some mistake?
Best answer by tank666
Nested-List component don't update overwritten labels - Prototype bug - #4 by tank666.
ksn
  • October 30, 2023
@Felix_Montana Hiya! Myself and the rest of the team took a moment to replicate the flow you described, and it didn’t look like there was any issue.
We may not have been testing the right scenario, though 🤔 Are you able to share a copy of the flow/prototype you’re working with so we can take a look? Or a screen recording would work too.
If you’re able to do that, and would prefer to move this conversation to support for a more private convo, lmk.
Felix_Montana
Hello @ksn thanks for your supporting. In this drive link I attached you the case. I hope you can help me.
tank666
  • November 22, 2023
Felix_Montana
Thanks, I hided the elements and it´s worked. Thank you!
