Figma App is lagging so bad
Giulio2
Hi,
I’m having problems with a few files in Figma; they lag a lot. For instance, when I try to duplicate or just move text, it lags significantly. I checked the memory usage on Figma, and it shows that the entire file is using only 0.8% of memory. I don’t understand why it is lagging so much if it is using less than 1% of memory. By the way, it lags even if it’s the only program open. I tried a command that cleans the app cache, but it didn’t change anything.
Figma is update and my Mac is too.
What am I supposed to try now?
harsha20599
  • 14 replies
  • July 1, 2024
I do have the same problem.
Whenever I run commands like select all text layers, Figma just breaks and becomes irresponsive.
Matthew_Wood
Same issue here…
  • 3529 replies
  • July 4, 2024
Hi there! Sorry to hear you are having performances issues.
This looks odd, clearing the cache can help as sometimes issues in the app may be caused by something stored in the Figma app cache. The restarting step usually helps to make sure that the cache is properly cleared before reinstalling the app.
For others who want to give a try, please follow the steps in this article:
Figma Learn - Help Center
If it still doesn’t help, please reach out to our support team (with URL link to the file which is effected, share a quick screen recording or screenshots demonstrating this issue and precise if this is happen in the browser, desktop app or both) so they can investigate further: here Thank you!
Giulio2
  • July 6, 2024
Thank you for your support. Unfortunately, even after clearing the cache, nothing changed in the app. I understand the importance of sharing the problematic file, but I prefer not to do that as it contains confidential material. I will try to recreate the issue in a new file and then send it.
Julius_Klaus
Same issue here, noticed it yesterday. Working on the same file for weeks now, nothing has really changed in complexity. I’m on the web app.
Arkasha
  • 7 replies
  • July 30, 2024
same issue desktop/web and mac/win
Fakhrxe
  • August 12, 2024
same issue here, they always crashing when i open the app
KennLucas
  • 224 replies
  • August 12, 2024
+1 on this. Slow performance all weekend.
KennLucas
  • 224 replies
  • August 12, 2024
It is not a file issue. Don’t let them make you jump through hoops! This is not your problem.
ksn
  • 1653 replies
  • August 12, 2024
Hello all - I’m sorry that this seems to be an ongoing issue for you.
I know some of you may have already tried troubleshooting, and it hasn’t helped. A couple of things I’d recommend trying as well, just to cover all bases:
-If you’ve already cleared the cache and cookies for Figma specifically already, open your choice of browser, and open a window in Incognito mode. Try loading Figma there to see if there are still issues.
-If you’ve not tried already: please try uninstalling the app completely, reinstalling, restarting your computer, and testing again.
At this time, since it sounds like it’s not an issue with a specific file, I would +1 @Celine_Figma’s message, and recommend filing a support ticket here. If the behavior is still slow, then that is something our tech quality team has requested be reviewed by them.
sandy_aguero
After the update, lagging has been a big problem. Is there a solution to this yet?
ksn
  • 1653 replies
  • August 29, 2024
2 posts were split to a new topic: Figma app lag issues
ksn
  • 1653 replies
  • August 29, 2024
Hi all - if you are running into similar issues as mentioned in this topic, please post here: Figma app lag issues
This topic will now be closed, since it is a bit older. Thank you!
