Feature Request: Image Links
Craig_Barron
I’m exploring moving from Miro to Figjam…
Something powerful in Miro is the ability to turn anything (including images) in to a link, thus building a visual representation of navigable structures. I see Figjam only has the ability to turn some elements in to links (and annoyingly has to have the full link text visualised)
I wonder if this is something others would value too…
Avokadomos
  • Active Member
  • 377 replies
  • August 11, 2022
You can turn any text into a hyperlink without changing the text itself.
As for images, you can just use the open link interaction:
Craig_Barron
Thank you I will explore further!
Avokadomos
  • Active Member
  • 377 replies
  • August 15, 2022
You’re welcome. Let me know if you have any more questions. You can click the checkbox under my previous comment if it works as a solution for you.
Craig_Barron
Thanks, it’s a partial solution. The real thing here is being able to link from a shape or a group! 🙂
Craig_Barron
image, shape or group! *
Avokadomos
  • Active Member
  • 377 replies
  • August 15, 2022
Did you try the open link interaction mentioned above?
Demo:
Craig_Barron
Ah - I don’t see this option. Can I clarify that we’re talking about Figjam and not Figma here pls?
How should I find this menu pls?
Avokadomos
  • Active Member
  • 377 replies
  • August 15, 2022
Can I clarify that we’re talking about FigJam and not Figma
This detail completely escaped me, my bad. This forum should really improve the tag system. 🤕
FigJam is very limited in this regard. You can add text to shapes which you then can link. Linking whole shapes or images is not possible to my knowledge. I suggest adding your link as a separate element.
Below, I’ve used the link widget.
Craig_Barron
Ok cool, thanks for your help - this can work(ish) for now 🙂
Avokadomos
  • Active Member
  • 377 replies
  • August 15, 2022
I agree that this should be a feature though, so I’ll upvote this.
  • November 13, 2022
