Elements inherit drop shadow from parent frame?
  • November 23, 2021
  • 6 replies
  • 3514 views
Stefan_Steigerwald
Hi!
When I make a parent frame with drop shadow and add child frames to it, these child frames will also have drop shadow. Is there any way to prevent this behavior? I only need to have drop shadow for the parent frame and not child frame.
Sketch Dialog2021-11-23 at 17.34.11
Best answer by Josh
The elements themselves aren’t getting a drop shadow, they’re just affecting the shape of the parent frame when clip content is off. You can definitely still use autolayout. However I don’t think you can get that overlap look with autolayout since it doesn’t support negative margins
Josh
  • Former Community Manager
  • 1019 replies
  • November 23, 2021
Those internal frames are a part of the parent and thus reflected in the final shape. In order to not have them do this, you’ll need to pop these outside and above the frame with the drop shadow. You can than nest both of those into another parent frame or group if you want to keep them together
Stefan_Steigerwald
there problem in this case is that I won’t have the drop shadow any longer but I can’t use Auto Layout any longer since the red and grey element are no longer nested in the yellow frame. it is a pity that I can’t just deactivate that the elements inside of a frame inherit drop shadow. makes no sense why this happens in the first place. It won’t happen with Inner shadow.
Josh
  • 1019 replies
  • November 23, 2021
Stefan_Steigerwald
thank you, clip content did the trick! I did not actually need the overlap, I just showed it as demonstration. so I’m sorry for the confusion but clip content works perfectly!
Josh
  • 1019 replies
  • November 23, 2021
Ah got it. Glad you got it all worked out!
  • December 23, 2021
