Create auto layout button with combine shapes
  • February 13, 2021
  • 2289 views
Resam
Hello all!
I was wondering if it’s possible to create a 3D button with auto layout? I can’t seem to figure this out. Any help would be much appreciated. Thanks in advance.
Screenshot 2021-02-13 at 14.09.43
Best answer by Gleb
It’s not a simple task but it’s possible. You just need a bunch of shapes and auto layouts. I just added an example of such button to my Auto Layout Tips & Hacks file on Figma Community: https://figma.fun/nlzApu
  • February 13, 2021
Resam
  • February 14, 2021
AMAZING! Thank you very much @Gleb. You’re definitely right in saying it’s not a simple task. Even after inspecting what you had done, It still took me a bit of time to understand it. I wonder if there is a way to stretch the button and make all the elements resize perfectly. The only way I can do it is by going in the ‘middle’ layer and changing the padding in the auto layout setting.
  • February 14, 2021
If the answer solved your problem, feel free to mark it as a solution. 🙂
Yes, you can make it manually resizable, but for that you’ll need to change the frames called “middle” and “horizontal” to fill container. Maybe you can avoid that somehow but I haven’t found a way. I just added an example to the file, you’ll need to duplicate it again to get the updated version.
