Change between variables modes in prototyping
Gustavo_Lopes
I’m trying to animate a small example that changes the mode of the color variables I have between dark mode and light mode, but the button just doesn’t work, what am I doing wrong? Is there a need to have some pattern between the names of the variables in the colors or something like that?
Best answer by Gustavo_Lopes
now it’s working! I believe it was because the page theme was set to “Light”, so it didn’t change. I put it in “Auto” and now it worked in the test file. Thanks!
Gustavo_Lopes
  • July 8, 2024
Hi there! This looks odd, it should work. Not sure which root cause may be 🤔
Can you double check if you have followed the steps as explained in this help center article:
https://help.figma.com/hc/en-us/articles/15253268379799-Variable-modes-in-prototypes#h_01HX7CHX3QAK0Z72XTPY98A8Q6 Let me know if this helps. Thanks!
Gustavo_Lopes
  • July 11, 2024
Ah great! Glad to hear you have found a fix. Thanks for letting me know, I’ve gone ahead to mark as solved , and closed the topic! 🙂
