Can't use "create component set" with component properties
  • May 13, 2022
  • 1560 views
Floran
Hey !
By the past, I was making all my components as frame, with renaming like for example :
  • Button / Primary / Hover
  • Button / Primary / Disabled
and at the end I was doing “create component set”. I did like that because I feel unfriendly the creation of variants directly inside the component mode. Renaming is harder to do than in my way, when you create a new variant it’s not positionning at the right place so you need to move it etc …
But since the new update, I wanted to use “component properties” for toggling element etc … but the fact is :
  • You can’t create component properties on something that isn’t component
  • To make a component set, you need to select elements that are not already composants
So I can’t use my method. What the greatest method for you to create variants ?
  • June 12, 2022
This topic was automatically closed after 30 days. New replies are no longer allowed.
