Button Variants: How do I prevent swapped icon overrides from showing after setting icon property to "none"?
  • February 1, 2021
  • 5 replies
  • 2988 views
MadsHenriksen
First of all, I apologize if my question is a bit confusing - I found it very difficult to describe the issue I’m having 😅
So I have this button component that uses Variants. The component has an Icon property that can be set to None / Left / Right / Both, and it works great!
Swapping the nested icon also works as intended, but if I, for some reason, decide to hide the left/right icon later (e.g. Icon: None), the icon still shows.
Any idea of what I’m doing wrong here? 🤔
If it helps, my button components has the following layer structure:
Thank you.
Best answer by Bruno_Figueiredo
Hey, @MadsHenriksen
I explained some best practices here so this doesn’t happen:
Figma – 1 Feb 21
Basically, you should wrap your “icon collection” instance inside a new Icon component that is the one attached to the variant properties.
Bruno_Figueiredo
Hey, @MadsHenriksen
Figma – 1 Feb 21
MadsHenriksen
That did the trick!
Thanks @Bruno_Figueiredo
Thor_Johannes_Wang
Nice! But this does mean you need to go a level deeper when replacing the icon. Which may not be very intuitive for people who don’t know about this workaround?
Bruno_Figueiredo
@Thor_Johannes_Wang Yeah, and I believe the Figma team is working on this for the upcoming Figma Variants updates.
h.rude
  • 42 replies
  • October 7, 2021
@Bruno_Figueiredo Your solution worked just awesome!! I was really grateful for that … but all of sudden Figma stopped swapping the icons AT ALL?! Is that a bug or did something happen so the concept above is not working anymore?
