Bug: Exporting to PDF adds a random box around my links
Show first post
Parnia_Parvizian
Thank you so much. That’s work for me.
Zarah_Sergison
Sadly, this work around is not easy when you have at least 20 link in a doc and have multiple versions…
JKR
  • August 28, 2022
Just export pdf no link from figma.
Then open it with foxit reader and use hightlight (shortkey - T) to select text you want put link. Press RIght mouse => create link => Thickness: 0 => next => paste link => done.
Li_Yizhang
THank you so much! It is really helpful!
Denis_Somar
I put a small visual walkthrough on how to use this Terminal command in Figma community for anyone that isn’t familiar with the command line.
Figma – 11 Jan 23
Darrin_Higgins
Figma please fix this simple but annoying little thing!
Hypermatic
Hi friends, if anyone is looking for another option for resolving this, our TinyImage plugin exports compressed PDFs without any outlines around links by default (you can optionally turn them back on in the plugin settings if needed). Hope it helps someone coming across the thread 😊
Tasha2
  • February 1, 2023
Thanks 👍
Solution 3 worked great, thanks a lot!
Hi could you please help me? I am trying this command, but it keeps giving me this message, " ‘sed’ is not recognized as an internal or external command,
operable program or batch file."
What should I do?
  • 4710 replies
  • April 30, 2023
sed is only available on unix/mac by default. Maybe this will help: windows - Is there any sed like utility for cmd.exe? - Stack Overflow
Or see my answer for alternative solutions: Bug: Exporting to PDF adds a random box around my links - #3 by Gleb
Thank you!
Victor40
  • June 30, 2023
It works. Thanks a lot.
busybox
  • July 22, 2023
Also having this issue when uploading a PDF to LinkedIn as a résumé.
tom_longmate
Here’s what worked for me:
  • VSCode (or other text editor): find & replace all instances of
    /Rect
    with
    /BS<</S/S/Type/Border/W 0>>/Border[0 0 0]/Rect
  • September 25, 2023
hero - this worked THANK YOU! Future generations will refer to you as the Bug Slayer 🥹
Yes, you have to!
Avidclan_UI_UX_Designer
it steal also bug can’t fix in 2023 also.
Matt_Kurvin
So good, thank-you!
