Assigning elements from nested components to properties
Phil_Larsen
A limitation I’ve noticed with the updates to component properties is when I have nested components that I am trying to control text layers from.
The text layer above is what I want to assign to the property of the overall parent component, however, it is not an option.
I don’t want to break the link because the component is being used throughout the project I am working on.
Any suggestions? It isn’t the worst thing, but having the ability to discretely indicate what informs a text layer is really helpful when you’re jumping between variants.
Aidan_Simpson
Our design system is also running into this issue. We use a couple of sub-libraries that rely on a master library components. We would really like nested, or child, component properties to be changed from the parent.
We really want to lean into properties and remove the amount of variants we current have for simple boolean action.
Any help would be appreciated!
  • August 23, 2022
