Anyone having issues with background blur
Paul2
Hey,
so i am trying out the UI Glassmorphism style, but I need the function of the background blur to do that. I can change values to the max without changing the blur…
anyone with the same issue?
best
Paul
Best answer by Michel_Sfeir
@Paul2 @Mark_Aldrich I had the same issue today, think I might know why it wasn’t working:
I was using a saved color in the “Color Styles” which for some reason doesn’t recognise the effect.
Try setting the color manually for the element, and reducing its opacity slightly, should so the job 🙂
Yorbi_Barriento
Hi Paul!
Are you changing the fill’s opacity?
Mine is working fine!
Mark_Aldrich
Im having the same issue right now
Michel_Sfeir
_jase
  • December 30, 2021
worked, thank you!
Jaz_Madhu
Hi Yorbi,
Thanks for the clear msg, I faced the same issue, then realized after seeing the screenshot “Pass Through” must be 100%.
I had kept the fill as 100% and reduced in “Pass Through” to 50%.
Thanks again, have a great day.
Alex_Kirkland
Thank you! This fixed it for me 🙂
Qonita_Afnani
Thank you!!
Milcho
  • September 9, 2022
Thank you Michel, problem solved.
marz_star
you just saved me another I-don’t-know-how-long going crazy thinking either I suck or figma is broken. YAY community!
I Never change the layer style opacity, that I know of. but mine just now was set at 18. I made it 100 and BAM it went from no blur to mega blur.
FWEW
thank you
Joy_Scopa
this just won’t work for me 😭 i’ve tried adjusting the opacity, layer fill, color…nothin. anyone else still having this issue?
Jordan16
set the fill to a percent less than 100%, (i set it to 20%).
Martin_Stech
Hi, I need to use Colour style because I have many themes.
@Figma_Support Can you fix this bug please?
Narendiran_J
Yes, reduce the background blur effect, keep it below 10
Narendiran_J
12345
Aaron_Kato
I’m usually just changing opacity by pressing the numeric keys that are changing the opacity of the layer and not the fill. Now as I’m changing the fill instead of the layer opacity, the magic started to happen 🙂
Caesar_pb
Thanks!! Seeing the screenshot i realise now that my issue was that i was lowering the layer Pass through instead of the Fill Opacity.
Frankie3
I had the same issue, and realized I applied the Blur to the whole component; once I removed it and applied only to the background shape it finally worked. Thanks for all the tips!
  • December 13, 2023
You`re the best! I was on the verge of beating the head against the table. Thank u soooo much!
aforammar
i am still having issues with background blur. i had tried everything.
aforammar
please anyone can help me?
Prabhat_Kumar
I’m having the same issue… and I don’t want to work anymore bcoz this effect plays a very important role while designing… plz help me
Prabhat_Kumar
Me too… I’m also struggling with it
  • March 5, 2024
Thanks for flagging - if you tried other solution that Community shared and the issue still persists, could you reach out directly to the support team with a copy of your file: https://help.figma.com/hc/en-us/requests/new?
Toku
