Unable to successfully publish update a figma file
  • May 17, 2023
  • 6 replies
  • 737 views
YorKun
Unable to successfully publish update a figma file for the community: “Error unloading images”,I had tried many times these days, and I guarantee that everything on the network is working.
Best answer by Celine_
Hi @YorKun ,
Can you please send back the error message you have seen in your end here? The picture doesn’t work.
  • As reminder, Figma only supports PNG , JPEG , HEIC , GIF and WEBP image and mp4 video formats.
  • If your networking is working well (internet speed and connection), please also make sure that it is not blocked by a browser extension. Browser extensions, such as ad blockers, can prevent images from loading in presentation view.
You can disable the browser extension, or add figma.com to the extension’s allow list. The process for this varies by extension, so make sure to reference the documentation for the relevant extension.
As of August 2020, the following extensions are known to block images in Presentation view: Ghostery, Video Downloader PLUS, iDM Integration Extension, Honey.
  • And, if you are using Figma in the browser: quit your internet browser application, then relaunch it.
    or in desktop app: right-click on the file’s tab and select Reload Tab.
Hope it helps!
YorKun
  • May 17, 2023
  • May 18, 2023
Hi @YorKun ,
Hope it helps!
Margaux
  • December 7, 2023
I have the same issue, I’m using the desktop app, I’m not adding images manually I’m just using the new thumbnail of my file. But everytime I try to publish I get the “Error uploading images”.
  • yes my network is working correctly
  • yes I tried by using a PNG
  • yes I tried after Reloading the tab AND Reloading the app
  • I’m using the desktop app so there should not be any browser extension issues
  • I tried publishing the update without changing the image and it worked fine
  • I tried publishing with the new image in 2 different browsers anyway, still didn’t work
Margaux
  • December 7, 2023
CleanShot 2023-12-07 at 11.00.28
Here’s the error I have
  • December 12, 2023
Hey Margaux,
Thanks for the details! Hmm it seems odd, please reach out directly to the support team and indicate the steps you’ve done by filling a form here: https://help.figma.com/hc/en-us/requests/new Our technical team can have a deeper look into what’s causing this. Thank you.
Margaux
  • January 17, 2024
I will, thank you
