Explanation
When creating a component, with variable text as a property and filling its text with 2+ token variables (with 2+ modes) sourced from “local variables”.
Instances with text variants (different text content) break on a “local variables” mode change, resetting its text content to the component property default & forcing it to stay that way (unable to change)
Replicate
  1. Create 2 local variable with 2 modes
  2. Create a component with text (text content as a proeprty of Component)
  3. Make text from component have different colors sourced from variable of step 1
  4. Create an instance and change its text content
  5. Change variable mode (at instance “Appearance” design section)
  6. Text Content gets resetted to orginal component default property & its unable to change
Example
Hi there,
Thanks for reaching out. I think I could replicate this behavior, and I'm checking if this is a feature limitation or a unexpected behavior with our internal team .  I will get back to you when I have anything I can share with you.
Thanks for your patience.
Toku
Hi ​@Bruno12
Thanks for your patience! Our product team has recently fixed this issue. If you still encounter this issue, please feel free to let us know.
Toku
