There’s a bug with the dropdown shadow when exporting a layer.
(This is the PDF file that I exported from Figma). As you can see in the PDF format, there are some white outlines near the drop shadow which I didn’t insert. Also, the blur effect is removed from the left edge of some layers. JPG/PNG seems to work perfectly fine when exported, but I want the project in the PDF form. If there’s any workaround, please reply. Any help is appreciated.
Bug when exporting to PDF
