Boolean variable binding removed in component
Iza_Zurczak
I made a boolean variable that checks if number value is one, and if it is then button should change state (default - disabled). The instance of this button is bound thith that boolean variable, but only if it stays NOT nested within another component.
I wanted to use that interaction in quite complicated “frame scenery” - heavily nested itself, so I got pretty frustrated that I cannot use it at all.
Is it some development bug or did I do something wrong? Maybe you could suggest a way around it if it was my fault indeed?
Best answer by Alex184
Figma doesn’t support this yet!
Variables can only be applied to top-level instances, and are not available for nested variant instances
Figma Help Center
ZAYD_OUNI
Same problem for me, i’m experiencing some issues with variable binding as I cannot bind a variable unless it’s an instance, it will be super beneficial if I can bind in the master component so I don’t need to bind each time I’m using that component…
also I noticed that binding isn’t stable when it comes to string type, i make sure i bind a variable then when i go back it’s not there…
hope Figma respond about it and I’m. sure they are receiving a lot of feedback as this is the beta version so I’m expecting a future update.
Alex184
  • July 18, 2023
Figma Help Center
  • August 17, 2023
