Figma top bar UI interferes in the prototype view
Leonardo4
When viewing prototypes the top bar of the UI interferes and it’s impossible to see and/or interact with the very upper part of the content, such as headers and menus.
It would be very helpful if the UI would appear on top of the content and not over it.
Boram1
  • June 22, 2022
You can easily disable the UI while prototyping.
Anthony_Loven
This isn’t great, there’s no reason that top-bar should appear on top of the design at all. Hiding the UI also hides the sidebar to toggle flows. The design frame should start below that bar, I don’t recall this behavior in early versions of Figma
Joyce_Lau
Same problem here. I want to be able to see the starting flows list and my prototype without the top cut off.
xMOx
  • Active Member
  • 24 replies
  • July 28, 2022
I agree on this one, that bar has definitely been an unpleasant experience when it comes to reviewing your designs. I don’t like that it is enabled via hover, it’s very tricky how it behaves. There are 2 ways to fix this! The easiest one is to not have the bar appear above the design so having it at the top and always visible and push the design preview down.
OR
A much better way is to make that bar a sidebar on the right and thus it’s not overlapping on top of the design. I also simplified the UI to use icons instead of text BUT I included tooltips when the user hovers over these actions. See the attached image for details.
As always much love for Figma and their amazing team for making an awesome product for designers.
Eduardo_Viva1
I strongly agree with you, i think movin the tob-bar into a sidebar would make a lot more sense, and bring a lot less frustration into the prototype process.
I dont think moving the screen below the top-bar would be a good idea cause it would make the screen size (height) smaller
Stanl
  • 4 replies
  • October 27, 2022
I don’t understand under which scenario we would want the ui bar to overlap our design…
Kuka
  • 6 replies
  • October 28, 2022
Agree! Looks like this request is related to this: Figma prototype UI obscuring fixed website header - #11 by Sam3
Please upvote there as there’s already a bunch of votes and discussion.
  • January 26, 2023
