Width parameter by default selected in Scale mode
  • October 16, 2024
  • 31 views
Alexis_Dam-Van
Hello there !
Just to bring back the Width selected by default when i enter in the scale mode.
Indeed, i used to directly type the size when i entered in scale mode, and use tab to switch between Width or Height.
Now, size multiplicator is the default selection and using tab just bring you on the anchor point selection. I have to take the mouse to select width/height parameter.
Sounds like not a big deal but it used to save time and movement during my work flow.
I’m not sure if i’m the only one thinking like that but modify directly width/height parameters have much more sense than the size multiplicator.
Capture d’écran 2024-10-16 à 11.09.22
Thanks to the Staff ! ☀️
Karolina_Kucerova
I was just about to post the same thing. It’s frustrating because usually when scaling you need a specific W or H value, not a % of the original value.
I think it’s a remnant from UI2 where the multiplier was the first option in the scale tool hierarchy, but in UI3 it’s 3rd, and the default selection just didn’t get updated for UI3.
So, please Team Figma, this shouldn’t be difficult to address!
