I have this table cell that has a swappable component inside of it. If i swap the default content of the cell with a button, the cell i expect the cell to “hug” the button / expand in height. Instead the button height does not change regardless of set size - sm, md, lg. What am i missing?
Try figure out with details you provided
Wondering what do you see when you select a button inside that cell? Does it show it hugs or fixed?
The button inside has a fixed height
Double check that:
- The button components are using auto-layout → hug/hug
- The button instance inside your cell component → hug/hug
- The main cell component is also auto-layout and has “hug” set on the height.
That’s the root cause, once you fix that to hug contents you’ll be fine
That fixed it. Thank you!
Absolutely! Thank you!
