Why doesn't a map work in actions array for reactions?
  • August 3, 2024
  • 16 views
Asaad_Mahmood1
I am trying to do this:
            const focusReaction: Reaction = {
                trigger: { type: 'ON_CLICK' },
                actions: [
                    // Set the current focusFlag to true
                        type: 'SET_VARIABLE' as const, // Explicitly setting the type to 'SET_VARIABLE'
                        variableId: focusFlag.id,
                        variableValue: {
                            resolvedType: 'BOOLEAN',
                            type: 'BOOLEAN',
                            value: true,
                    // Set all other focusFlags to false
                    ...variableObjects
                        .filter((vo) => vo.focusFlag.id !== focusFlag.id)
                        .map((vo) => ({
                            variableId: vo.focusFlag.id,
                            variableValue: {
                                type: 'BOOLEAN',
                                value: false,
But it just doesn’t work, it complains about types etc but it seems like another issue.
Here’s the error:
code.ts:125:21 - error TS2322: Type '{ type: "SET_VARIABLE"; variableId: string; variableValue: { resolvedType: string; type: string; value: boolean; }; }' is not assignable to type 'Action'.
  Type '{ type: "SET_VARIABLE"; variableId: string; variableValue: { resolvedType: string; type: string; value: boolean; }; }' is not assignable to type '{ readonly type: "SET_VARIABLE"; readonly variableId: string | null; readonly variableValue?: VariableData | undefined; }'.
    The types of 'variableValue.type' are incompatible between these types.
      Type 'string' is not assignable to type 'VariableDataType | undefined'.
125                     ...variableObjects
126                         .filter((vo) => vo.focusFlag.id !== focusFlag.id)
134                             },
135                         })),
[2:41:22 PM] Found 1 error. Watching for file changes.
  • 4710 replies
  • August 3, 2024
Try to cast variable value type to VariableData
variableValue: {
    type: 'BOOLEAN',
    value: false,
} as VariableData,
