Why does Figma alter typefaces?
  • August 19, 2024
  • 5 replies
  • 228 views
The top text is the Figma’s version of Poppins. The bottom text is the CORRECT version of Poppins. Even after downloading the Google version, it still shows the apostrophe being off. And other elements of the typeface are like this as well. There are other instances of this.
My question is: WHY? And how do I fix this, its driving me nuts.
  • August 23, 2024
Thanks for reaching out. I’m checking with our internal team. I will get back to you when I have anything I can share with you.
Thanks for your patience.
  • August 24, 2024
I’ve checked internally and found that unchecking “Substitute smart quotes” will keep the text as straight quotes. If you uncheck this option and type, it will display straight quotes instead.
Hope it helps!
Thank you, sir, I was just about to ask the same question, but you provided the solution even before I had the chance. I guess I’m lucky today 😀😀😀😀😀😀😀😀😀😀😀😀😀😀😀
  • August 26, 2024
Glad it worked! Your day will be bright!!
Yeah, it was amazing thanks to you i just delivered the project to the client, and he really liked it. 😊😊😊😊😊😊😊😊😊😊😊
