What does pressing command do after starting to drag?
oscargodson
I noticed today when I start dragging an element then hold down command after starting to drag my cursor has a little down arrow under it. I tried to screenshot but even with a timed screenshot the Figma cursor is not appear in my screenshot.
Is there a list of key commands when dragging? I couldnt find any info on what this means nor info on dragging commands.
Thanks!
  • 2545 replies
  • January 30, 2024
Thanks for the post! I am checking with our internal team. I will get back to you when I have an update that I can share with you!
  • 2545 replies
  • February 1, 2024
@oscargodson This is to allow the user to deeply nest a node. It basically allows you to reparent the node you’re dragging in certain circumstances where we’d otherwise not do so.
Here is the example when the layer is bigger than the frame.
I hope it helps!
