What are problem with Undo in Figma? Too much press Command+Z
Ino_Nguyen
I feel its difficult to undo the action, the select action stack in action history, i must pess too much ⌘+Z to undo necessary action, not like any app other. Is there any way to fix this issue?
  • May 23, 2021
There is no action history but you can undo big changes that happened a while ago from version history: https://help.figma.com/hc/en-us/articles/360038006754-View-a-file-s-version-history
Erkan
  • July 29, 2021
I feel like this question is not addressed.
I have realised the same thing on Figma.
The best practice of using Command + Z doesn’t include the steps of select or unselect actions.
An example; you are on a page and you created a rectangle (1), and click somewhere else (unselect the rectangle) (2?). Figma takes these as 2 separate steps and you have to do two times “Command + z”, only then the rectangle is gone and you come back to where you were. The first “Command + Z” will only select the rectangle.
This creates the problem of inconsistent user experience compared to all other computer applications. I have never seen this type of an experience. To be able to come back to where I want, I have to use Command + Z a lot because of these unnecessary steps.
  • July 29, 2021
Once you get used to it, it’s amazing.
You can vote for this feature in this thread: User Preference to include or exclude object selection in undo
Yusuf_M
  • December 9, 2021
No. It’s not amazing at all. If someone uses Figma 24/7 for even word editing and excel sheets then yes it is amazing. For the rest of us, it is super painful to have 3 unnecessary undo taps that were basically selection inside a selection inside a selection. This behavior is against every tool we use out there and also defies Fitts’ law and Jakob’s law of UX.
RichbutUgly
Not amazing at all
Rayan
  • February 9, 2022
Can you please tell us what do you find amazing about it?
  • February 10, 2022
  1. If you click in the wrong spot while doing a complex multi-layer selection, you don’t need to start over (drives me insane in other apps).
  2. Moving around the pages and canvas selecting different frames, then being able to easily go back if necessary.
This gives me an idea for an improvement, I’m gonna add it to the active feature suggestion thread. User Preference to include or exclude object selection in undo
  • February 20, 2022
This topic was automatically closed after 10 days. New replies are no longer allowed.
