Variant Issue with Nested exposedInstances and Switching Off Instances
  • March 26, 2023
  • 318 views
all nested props are on 👆
one of the nested props is off 👆
I have noticed that when a variant contains nested exposedInstances instances, and you switch off one of them, exposedInstances returns an error. However, I believe that this shouldn’t be the case, as Figma allows this action. Instead, it should simply remove the switched-off instance from the array or add a specific property, such as unchecked. Am I missing something here?
Best answer by PavelLaptev
I found what cause that. I had a line to skip invisible layers:
figma.skipInvisibleInstanceChildren = true;
Just remove it.
  • 6 replies
  • March 26, 2023
Just remove it.
