Lachezar_Hubanov_SI
Nov 20, 2024 5:25 PM UTC
[URGENT] Issue with Variables in CodeGen plugin
Hi,
I work on a plugin that uses codegen to generate css code in dev mode. All the devs on the team noticed that suddenly the syntax around variables changed significantly, so I suspect yesterday’s update.
I am quite perplexed at what needs to be handled differently now as the plugin just calls codegen.on() and then uses node.getCSSAsync() to return all the CSS data from the current selection (we format it after the fact for our use case).
Since the update this is the CSS syntax we get:
Seems like every time a node uses a variable that exists in the project we get this corrupted unfinished comment block.
I need a workaround pretty urgently, so if there’s a flag to turn the comments off would be super helpful! Or any sort of other setting that will at least provide me with valid CSS syntax!
Best,
Lachezar
scott.mail
Nov 21, 2024 8:43 PM UTC
Yes our team is running into the same issue and has logged bug report #1180827 on this. @Alden_Lo.
Also noticed that this was mentioned in Figma’s Discord forum here…
Discord
jefflee
Nov 21, 2024 11:41 PM UTC
Hey folks, thank you for the bug report here. This issue seems to be related to some recent feature releases earlier this week, which we’ve rolled back temporarily while we investigate further. Hopefully, that should resolve the issues you’re seeing with getCSSAsync(). Sorry for the disruption!
Lachezar_Hubanov_SI
Nov 22, 2024 11:34 AM UTC
Thank you for the speedy response, Jeff - this has indeed resolved the issue on our end. One last question - in the future- what’s the best way to raise any issues with the Figma dev team? Is there perhaps a better place to raise bugs/issues? I can’t seem to access the discord linked above
jefflee
Nov 22, 2024 8:35 PM UTC
If you have a pro plan or above, you can file a ticket directly with support. See:
Figma Learn - Help Center
Otherwise, the forum is the probably still best place.
Dalda_Brown
Nov 23, 2024 11:47 AM UTC
I also face this problem. Please give me answer in details.
