Dan_Owens
Jan 27, 2023 3:07 PM UTC
Unable to move project to another team
I’m trying to move a project from one team to another.
  • I am a member (editor) of both teams
  • Both teams are under the same organization
  • I have starred the project I want to move so that it appears in my Figma left navigation (so I can drag it to the new team)
  • When I drag it, I receive the error dialog “Unable to move project” - “Projects set as view-only cannot be moved between teams. To complete this operations, enable team edit access for [Project Name] and retry”
Gayani_S
Gayani_SSolution
Mar 21, 2023 2:36 PM UTC
Can you try to drag a file directly to a different project to see if that works? If that does not work could you clear your cache and try again, maybe on 2 different browsers (Mozilla Firefox, Edge, etc.). Alternatively I’d recommend contacting support, they will be able to investigate here further. Hope this helps!
Dan_Owens
Dan_OwensAuthor
Jan 27, 2023 3:09 PM UTC
Correction I am an ADMIN for the project’s current team, and I am the OWNER for the new destination team.
user36
Mar 21, 2023 3:56 AM UTC
Same question
Gayani_S
Gayani_SSolution
mcurtin
Jan 18, 2024 5:05 PM UTC
I was having the same issue with moving a project and files to a new internal team within the same organization. While looking at the project screen you are attempting to move, click the share button and confirm that the project is set to ‘members can edit’ as opposed to ‘can view.’ Changing this setting on the project allows it to move to a new team. After the project is moved, you have the ability to reset the ‘can view’ permission as needed.
This worked for me and hopefully solves your problem as well!
Mikka_Wild_adesso
Jan 24, 2024 12:38 PM UTC
Thank you! That also was the problem for me and solved it ✅
In my opinion this should be marked as solution.
Hernan_Nicolas
Feb 21, 2024 9:02 PM UTC
Guess they had a different opinion lol
