Typography - missing fonts
Aviad_Cohen
Hi, I downloaded Google fonts (Inter - all weights) and I’m using the Figma app on my mac, but I can’t use all the weights for some reason, only the regular, and when I try to use bold for example the font options become inactive …any clue what can I do to solve it?
Best answer by Aviad_Cohen
Hi, thank you for the help, but I checked and I installed as you mentioned - separate ttf files.
I reinstalled them and restart my computer - now it works 😃
  • 4708 replies
  • March 25, 2021
You probably installed the variable version of this font. Figma doesn’t support variable fonts. Make sure you installed all font weights as separate ttf or otf files.
Aviad_Cohen
  • March 25, 2021
Eduardo_Caliope
Hi, more one with this problem!
I tried the solution above and it didn’t work ☹
davelab6
  • 7 replies
  • April 14, 2021
GitHub - Tgemayel/variable-fonts-figma: A plugin to run variable fonts in Figma is a plugin that provides a workaround for VF fonts support
Suz_m
  • 3 replies
  • April 18, 2021
I have the same problem.
I have installed fonts on my computer in .otf version. I can not find any of these fonts in the font picker list in the Figma desktop client.
I have tried: Checking that the fonts work in other programs. Restarting my Windows 10 computer. Installing the fonts again. Using the Figma browser and the Figma Font Helper.
Other people are using the same versions of the fonts in Figma without problems.
I suspect the problem is in Figma and my computer somehow not communicating correctly.
  • 4708 replies
  • April 18, 2021
I’d recommend you to reach out to the Figma team for technical support: Submit a request – Figma
Suz_m
  • 3 replies
  • April 18, 2021
I solved it by reinstalling the fonts one at a time by right clicking on the font files.
