Tooltip Behind Bottom Element in AutoLayout:
  • December 20, 2023
  • 411 views
Marlon
I am trying to create a simple table, one of the cells in the table contains a “Tooltip” component.
It happens that when the table frame has an autolayout, the tooltip is below the bottom element.
While if I remove the autolayout it looks perfect above the bottom element.
How can I get result #2 using Autolayou?
I hope I have made myself understood, thank you.
Best answer by tank666
  • 4873 replies
  • December 20, 2023
Marlon
  • 4 replies
  • December 20, 2023
Indeed it was the “Canvas Stacking” configuration.
I had “The last one on top” selected.
I will keep it in mind for similar designs.
Thank you very much for the help.
Thanks for the Solution.
