The best way to design a large set of buttons
  • August 25, 2021
  • 5761 views
Molly_Hellmuth
I’ve created a lot of button sets over the years and using variants + base components is definitely the way to go! Here is my process:
Step 1
Create a base component for each button size (e.g. “Large”) and icon placement (e.g. “Right Icon”), name it “Base” and turn it into a main component.
Step 2
Add multiple instances of each base component and apply overrides to create unique types (e.g. “Secondary”) and states (e.g. “Hover”).
Step 3
Turn every unique instance into a main component, select “combine as variants”, and rename variant properties & values.
Step 4
Make bulk changes by editing the base components.
Base - C
If you want some practice or a starting off point for your next project check out my (free) Button UI kit
Button UI Kit: https://uiprep.gumroad.com/l/fAAgt?_ga=2.136435382.709511783.1629657346-34411364.1624652900
S.Frank
  • December 29, 2021
Thanks for sharing, I learned a lot!
Do you have a new strategy now once Figma added more functionality?
