Text not visible when typed text leads to outside the frame
Prashant_S_Ambetkar
Please search for existing topics before posting! Press 🔍 at the upper right to search.
screenshotnew
Haroll
  • 273 replies
  • March 4, 2024
Hi @Prashant_S_Ambetkar
Would you be able to explain a bit more about your problem? As it is not clear what you’re trying to achieve here
  • 2545 replies
  • March 5, 2024
Thank you for reaching out. I suspect that the text layer might not be fitting within the frame. Could you please check this? If you can adjust the size of the text layer or the frame, I believe the text should become visible. However, please let me know if I’ve misunderstood the issue.
Sample ↓
