Set a Conditional "Set Variable Mode"?
Stephen_Moy1
Is it possible to make a the Variable Mode toggle when clicking the same element/component? I’ve got it to work “On Click”. But then clicking the same element doesn’t change back.
Is the only way to do this, to have a component with two states of the same thing and have a different “Set Variable Mode” on each, to change back?
I was hoping I wouldn’t need to do that and instead create a toggle on the same element using a Conditional (like attached).
Any ideas? Thanks!
Screenshot 2024-05-25 at 18.04.25
  • May 28, 2024
Thanks for the feedback! It looks like this feature isn’t available at the moment. As you mentioned, you’ll likely need to use two states with different modes to switch between them using On Click actions.
I’ll pass this feedback along to our internal team for future improvements.
If you have any other questions, please feel free to reach out.
Stephen_Moy1
Thanks for the reply @y_toku! I hadn’t thought about trying that until the other day, I was pretty sure it wasn’t supported but just wanted to double check. So thanks for confirming and I do this with the two states for now.
Thanks again! 🙂
