Here is a video explaining my struggle
Can we have another checkbox to enable and disable fixed positioning for overlays?
Here is a sample in Bootstrap:
Hey @Hossein_Boroji
Would something like this work, if you set vertical scrolling on the entire frame that the modal content is in? You can use the manual setting for the overlay if you need it to be in a specific area. Here is an example:
Would you mind helping me out with this problem ? @Josh
Have you by any chance found out why it is disabled and grayed out when it comes to instances ? @Tom_Lowry
Hey @Hossein_Boroji I believe two things have to happen. First: scrolling needs to be enabled in the Main Component (it is not an overrideable property within an instance). Second: the frame needs to be smaller than the content in the direction you are planning to scroll, otherwise you will get a little warning when you set the scroll behavior. Hope this helps!!
Hey @Tom_Lowry OMG you were right on spot. I didnβt know I had to enable it in the main component. I also reduced the frame size to get rid of the error message
Thank you so much again
I donβt know how to mark this ticket as solved, otherwise I would have right now.
