Scrollable text field animation - problem
  • September 14, 2021
  • 5 replies
  • 2116 views
howard
I am trying to do a simple animation as a component for a prototype, but no matter what I do it doesn’t work (see images below). I’m trying to simulate a scrollable text field that needs to appear on multiple screens. On drag, the scrollbar and text should scroll. Has to be a component because it appears as an element on different pages (of a website).
Any guidance with this problem would be greatly appreciated.
  • 4870 replies
As far as I can see in your screenshot, you are using the “Scroll to” action instead of the “Change to” action of the interactive component.
Remove unnecessary interactions and set the action “Change to”.
howard
  • 5 replies
Thank you for the help. However, when I try to change that, there is no “Change to” available. Do you mean “Navigate to”?
  • 4870 replies
If you don’t see the “Change to” action, it means that you are not a beta test participant for interactive components. ▶ Sign up for the Interactive Components beta →
howard
  • 5 replies
Thank you. After digging further into the issue, I just discovered that a few seconds before your response. I’ll sign up for the beta. Thanks again.
  • October 14, 2021
