Running into "File out of memory" while resolving conflicts
richy
  • 6 replies
Hi! As of lately I run into memory usage issue when trying to update branches from main.
The resource usage overlay shows a number around 0.3 G, which is well below the 60% of 2.0 G threshold, so working with the file didn’t trigger any memory warnings so far. But when working in a branch and trying to update from main, I recently started to run into warnings while going through the “resolve conflicts” dialog. It starts with the yellow warning banner, with every resolved conflict the shown memory usage % increases, the banner becomes red and ultimately I get to see the “File out of memory” message and can’t continue.
I wonder if this is just a temporary limitation/bug of the beta or if it would be advisable for the future to keep files well below the 0.3 G to use the branching feature.
Anyway, hope this helps, thank you!
Best answer by djv
Hey All,
Solutions will be case by case, depending on your file. The forum is primarily managed by the community, so please reach out to the support team directly via this form for help: https://help.figma.com/hc/en-us/requests/new
Be sure to use provide a link to your file and share it with support-share@figma.com.
raquino
  • Figmate
  • 43 replies
  • July 20, 2021
Hi Richard,
Sorry you’re running into this issue. If you could DM me the link to the file (and share it with “support-share@figma.com”) we can look into this for you.
Best,
R.J.
Brandon_Thomas
Hey @raquino, we are also hitting this issue in some of our files. I had our designers write up a report on this and we have links etc along with repros, expected behavior and some suggestions for how to improve. Where can I send this document?
raquino
  • Figmate
  • 43 replies
  • August 26, 2021
Sent you a DM!
1111210
  • September 7, 2021
Hello! A similar problem with the file. We have already tried everything that was possible. Reduced the number of layers. There is still a problem. Compared with other files 3 times more, they have no such problem.
Aditya_Bhandari
I am currently blocked by this File out of Memory error. I’ve just moved from Sketch+Abstract and like to keep organize my work in branches.
While I have come to love Figma, I am extremely disappointed in the performance issues around merging files. If you cannot handle enterprise grade files, read somewhat heavy files, then please do not GA the feature. ☹
Catherine6
Still no answers to this?
Kroo_Design_Team
We have also come across this issue and is a big show-stopper. Can you please help provide a quick fix?
Kroo_Design_Team
Is there possibly another email address? When emailing to the email support-share@figma.com, I got the following message:
We’re writing to let you know that the group you tried to contact (support-share) may not exist
Nouela
  • 18 replies
  • September 14, 2022
Same issue here. Any resolution?
Katherine_Hajer
I just ran into this issue for the first time. The main file works fine, and I have never received any “running out of memory” errors in it. The single branch also works fine… until I try to merge the updates from main, and then I error out. It’s extra-annoying in that there aren’t that many updates to make.
One thing I would like to see updated is what gets put into a branch. It would be nice to have branches of single pages, rather than the entire file being branched. I only need the branch for one page, but I have to synch the entire file in the branch.
Chris_Sullivan
I’m running into the same issue. Both the main file and branch are under the 60% safe file limit and I cannot accept updates from the main file in my branch without getting an error saying that the file has run out of memory.
Mike_Zharchev
Same here, branches are unusable for something bigger than a few frames.
tfabb
  • 7 replies
  • November 9, 2022
Same issue here!
Mariella_Perez
Also experiencing the same issue. Is the only resolution to chat with support?
Carrie_Notte
I’m also having this issue and it’s extremely frustrating.
Both my Main and Branch are pretty clean in their builds and under 40mb combined. They were 112mb combined, but I took out some pages, hidden layers and cleaned up the components to reduce size and still have the issue.
Jayce_Yard
  • 10 replies
  • November 30, 2022
Ran in to this issue today as well. Looking to fix this
Denise_Carofiglio
Same issue, please fix this. I based all files on branches and now they’re not usable.
Kate_Yz
  • January 12, 2023
Also experiencing this issue. We just switched to creating a branch for each of our concept rounds, to avoid heavy memory utilization when iterating in the same file. The memory bug in the branches is ironically worse than the original issue, despite the resource use reporting at .6G. This is also for enterprise design.
Van_Tran
  • 8 replies
  • January 12, 2023
Can we please get a response from Figma on what’s being done about this? Thanks
Dhruv_Mittal
Folks running into the same issue, has anyone found a resolution to this?
Daniel.Ito
  • January 18, 2023
Keeping this thread alive, I have been receiving team reports of this problem and would like to know how to proceed
Matt_Rea1
  • 15 replies
  • January 18, 2023
Same here. I have a branch I’m trying to merge into the main file, and I keep getting this error message. Distributed teams all have the main file bookmarked and this is going to cause issues if they need to remap, lose comment history, etc.
Is there a workaround for getting my branch changes into the main file? Sounds like branches are not safe to use?
Kate20
  • 4 replies
  • January 19, 2023
This won’t work for every branching situation, but I was just able to get around an 80+ conflict merge that was throwing this memory error. Instead of going through each conflict individually, I hit the “Resolve All” option and picked one branch to use for all the changes. It merged quickly with no memory warnings.
Toby_Fitch_HE_HIM
+1 - been running into this issue for months at this point. Might have to resort to saving each version into a new branch. Can’t even merge to main.
Kolodziej_Ashley
I just wanted to say I just ran into this too - I was able to find a way around it by identifying a page that needed to be deleted to get the file in sync with main, but both files were originally at 20-25% of usage, so having this come up during the merge was definitely a surprise.
