Rules of text truncate
Aurelien_Barbier
Hello !
I and my team we are searching for information about the new function to automatically truncate text. Do you know how it works ? What is the rules of truncating ? Because we made some tests and we don’t understant how it works actually 🙂
Thanks in advance,
Have a nice day ☀️
carlhauser
Hey Aurelien,
Make sure your text has a fixed height (cuts it off horizontally) or is set to fill content when using auto layout, otherwise figma does not know where to cut off your text and turns “truncate” off. (you need to turn it on again, might be one confusing point) If you are not using auto-layout and just constraints you can set your text to for example left and right and top and bottom in the constraints menu to make truncating work.
Have a great day
Gabriele_Malaspina
I think @Aurelien_Barbier is referring to the rule behind the truncation feature. It’s pretty weird, sometimes it advances by one character, at other times by four. 🤔
CleanShot 2022-05-24 at 13.33.37
Gabriel_Mejia
You are right, rule behind truncation is really weird, I sometimes need only a few characters …but it truncates a complete word…
cc @Figma_Support
carlhauser
oh got it! This is also something I would like to know 🤔
Aurelien_Barbier
Yes it’s more about the rule behin truncation, not how to activate it 🙂
Thanks for your answers !
AllieJ
  • 6 replies
  • January 12, 2023
I’m also having this issue, sometimes it truncates in the middle of the word (what I want) and other times it will only truncate at the end of a word, leaving extra space rather than filling the whole frame.
Santiago_Mansilla
It would be useful to set if you want to truncate the text by word, by character, or by syllable! I need this
THNDRX
  • 7 replies
  • September 6, 2023
Yeah it’s very annoying sometimes that complete words are truncated out! We need more control over this
Michal_Swiaczkowski
Any update on that?
  • Figmate
  • 2165 replies
  • January 30, 2024
Hi All, Thank you for bringing this to our attention!
After checking internally about the text truncation rules, we expect that the ICU word break rules will be applied.
If you’re experiencing something different, would you mind ‌reaching out to our support team here?: https://help.figma.com/hc/en-us/requests/new?ticket_form_id=360001744374
Please be sure to use the email associated with your Figma account, and include the video of the issue you are facing.
This way, our team can go ahead and pass this along to our engineers so they can help us look into this further.
Thanks all for your help here!
cmkaniac
  • May 2, 2024
Any update on this, in plainer English than the “ICU word break rules”?
I’m working with a use case that is pretty common; i.e., I’m trying to create a simple banner notification with a title and timestamp that maintain 10 pixels of separation.
So, I have the title text set to “Hug” within an auto layout containing both text elements. This is then nested within another auto layout that controls all the banner elements. (e.g., icon, expand/collapse arrow, etc.)
Ideally, the title would ONLY be truncated when the banner width shrinks to the point that the title, timestamp, and expand/collapse arrow can no longer fit without overlapping or violating the padding rules of the auto layout. But I haven’t found a way to do this.
Setting a max-width on the title is a less-than-ideal solution, as I have to choose a narrow width that works with narrow banners. But when the banners are wider, the title text is still relatively short.
Also, it doesn’t resolve the truncation problem shared above whereby the text box extends by many spaces beyond the ellipsis.
Lukas_Low
  • October 18, 2024
Any updates on this? Struggling with a similar scenario in 2024 😃
Yuri_Ryzhenkov
Would also nice to add truncation positioning for long texts, where it’s important to keep visible the ending and the middle could be truncated.
mmmm
  • December 11, 2024
Running into this issue with two text layers that match in all settings truncating differently. One pulled from a nested instance and one as a fresh text layer, both exact same styles and width settings: one will lop off whole words while the other truncates letter-by-letter as expected.
CleanShot 2024-12-11 at 14.21.14
Ori_Solomon
I have this issue with RTL fonts the the 3 dots are overflowing the container. dose anyone encounter this issue and can help? (left, center and right alignment as well)
