Round the corners of a random shape
Jzzzoo
as indicated by the green arrows in the image, how to round the corners of an irregular shape like this?
Best answer by Avokadomos
It only works on points with two connections. If you delete the line that connects the two points through the shape, it will work.
Jzzzoo
  • 8 replies
  • August 28, 2022
outcome
This is the outcome I want to achieve.
Avokadomos
  • 377 replies
  • August 29, 2022
If those corners consist of only single points, you can select them and increase the vector corner radius.
Jzzzoo
  • 8 replies
  • August 31, 2022
I tried, but it didn’t work for the two points that I circled out.
Avokadomos
  • 377 replies
  • August 31, 2022
Jzzzoo
  • 8 replies
  • August 31, 2022
Thank you, that makes sense. The shape is a vector and I can’t find ways to delete the line between the two points, so I use Pen to outline a new shape and round corner all points, it works. Thanks!
