Resize image with auto layout
  • November 5, 2023
  • 2315 views
Andreas_Sjostedt
Hi everyone.
I am new to Figma and app-development. I am trying it out. I like the way to work in Figma and feel hopeful. I am stuck though, and it’s probably a quit simple thing. I am trying to add an image as a logo in the top of my screen. But I want it to follow as I am risizing the screen. I have understood that auto layout is the way yo go, and I should choose “fill” for the image to having it to “follow” the frame it is placed in. But that does not seam to work for me, and it feels like I have tried all different variants in the settings for the auto layout. It must be something I am missing. Can you see what I am doing wrong? How would you’ve done something similar to this? I am adding an image and put it in auto layout, where image is set to fill and frame (auto layout) is set to fixed. Here are some images:
Thanks in advance! / A
AlicePackard
  • 194 replies
  • November 6, 2023
Hey @Andreas_Sjostedt, I think if you update Frame 1 from fixed ↔️ to fill ↔️ you’ll see success! After doing that, you should be able to resize the outer iPhone 8 - 1 frame and the logo will grow and shrink to fit.
You may want to update the height of the Logo image layer to hug ↕️ though (currently set to fill ↕️ in your screenshots). Having it fill vertically could result in some weird distortions. You’ll find out when you try resizing the outer iPhone frame.
Let me know if this helps!
Andreas_Sjostedt
Hi. Thanks for your reply. I can not choose “Fill” on Frame 1…(?)
Do I have to enable something to be able to do that?
kind regards / A
Andreas_Sjostedt
Hi, sorry…I just wanted to say that I got it to work. I simply started over and then your tips worked… Thanks for that.
May I ask, I can’t stop thinking…why wouldn’t you always wanna use AutoLayout as a default? I don’t see why it can’t be always on, and if you would like to disable it for some reason you’ll do so. When would you NOT want to use that? I just trying to get in to the thinking…
Anyway, thanks for your help!
/A
