Replacing default icons not possible
  • November 23, 2023
  • 839 views
Tudor1
I’m using the Material 3 UI Kit and trying to replace the default icons (e.g. from a navigation drawer). If I try to paste a vector icon (from the material icons plugin), I can’t move it inside the state-layer, where the default circle icon resides. I have no clue how to do this.
  • 2545 replies
  • November 24, 2023
Thanks for reaching out. I believe the best way to get ‌support for this specific plugin is to reach out to the creator. It looks like there’re some ways to ping https://www.figma.com/community/file/1035203688168086460/material-3-design-kit
Having said that, I just looked into the kit a little bit, and have you tried ‘Go to main component’ of the icon (attached)? Once you click it, you can go to where the main component lives.
Screen Shot 2023-11-24 at 9.55.09
To replace the circle icon under navigation drawer, you’d need to create an instance of the component that you created in vector. This article might help you to swap instances, so I hope it helps: https://help.figma.com/hc/en-us/articles/360039150413-Swap-components-and-instances
I hope this could solve the problem!
Tudor1
  • November 24, 2023
I needed to detach the instance of the icon.
Thanks for the reply.
