Miki_UX
21
Hey Harsha, same problem: needed to replace a hundred components. Lucky thing is that they all have the same name. What I did is:
- Searched for that layer name, results showed
- I copied the component that will replace them (make sure it has a different name than the ones to be replaced)
- And then I just pressed cmd + shift + R until all the components in the results were replaced.
Manual, but worked for me in a matter of seconds. Hope this helps, thanks.
Using Select Layers plugin is cleaner… not promoting it, just is and it’s free:
- Copy your component
- Select all (cmd/ctrl + A)
- Run plugin called Select Layers - Select Layers by Name, exact match checked (or select any relevant category)
- Step2 selects all relevant layers, then simply cmd/ctrl + shift + R to replace all those layers.
Note: sizing and location have to be identical for replacement to be clean. Set your object/component how you want it before Step 1, then copy it.
How to Change Color of PNG/JPEG Image in Figma
