Remove borders on every layer in frame with auto-layout
Bohdan3
It’s just so annoying. I don’t understand what layer is selected when every text layer in frame is highlighting with borders. The only i can se is BORDERS
  • 4710 replies
  • June 30, 2024
This doesn’t happen to me. Can you show what you are seeing?
Bohdan3
  • June 30, 2024
This borders add so many unnecessary visual noise
  • 4710 replies
  • June 30, 2024
Have you tried restarting the file? I can’t find a way to see these borders you are seeing. Must be a bug.
Celine_
  • 3733 replies
  • July 2, 2024
Hey @Bohdan3 ,
This looks odd, I can’t also reproduce on my end. Is it only happenning in this specific file?
Can you try to restart the file as Gleb mentioned, and also tried to clear out the cache and force-quit to see if that helps?
If it doesn’t help, I’d recommend you to reach out directly to the support team: here
Be sure to use your Figma email account, mention the steps you have done, and a copy of your file and add support-share@figma.com as an Editor if you are able, so the team can try to replicate it directly. Thanks!
Bohdan3
  • July 2, 2024
It’s Figma slides. Maybe in Figma design files it looks differend in UI3, but in Figma Slides i have this issue.
Yes, i have restarted Figma app multiple times.
Celine_
  • 3733 replies
  • July 7, 2024
Thanks for clarification! I tried on Figma Slides, and it works on my end.
Hover layer:
Selected layer:
As mentioned, I would recommend you to reach out to the support team with a copy of your file if you are able to, your desktop specs so they can investigate it further: here
