BUG (investigating): Rearranging order of variant properties/text styles in dropdown
  • January 25, 2023
  • 22 replies
  • 6270 views
Mango_90
When I create new variant properties, or new text styles, the newest addition will land at the bottom of the dropdown list in the right hand pane.
Is there a way to reorganise these?
Best answer by djv
Thanks for providing the screen recording, @Alyssa_Maac1!
I flagged this internally, and it’s actually a long standing bug our team is aware of and trying to fix. I’m going to merge a couple of threads here in the forum together then pass it along to our team for tracking purposes.
So far, we haven’t been able to consistently reproduce this bug, except for within files that users have sent us directly. If you can send over a bug report with your affected file directly to our technical quality team, it would be a great help: https://help.figma.com/hc/en-us/requests/new
Be sure to use your Figma account email, include a link to your file, and share it with support-share@figma.com, so they can take a closer look.
  • January 25, 2023
You can change the order manually using drag and drop.
To change the order of the properties, select the component set, and then drag the properties you want.
To change the order of property values, hover over the desired property, when the component set is selected, click on the “Settings” icon, drag the desired values.
To change the order of the styles, deselect by pressing Esc or by clicking on an empty area of ​​the canvas, and then drag the desired styles.
Figma Help Center
@tank666 I’ve done this successfully numerous times on text styles within the panel, but there are two styles (H4, H5) that won’t let me reorder them. When I release the mouse button, they just go straight back to the bottom of the list. All the other styles can be moved around as needed just fine. Any ideas?
  • March 1, 2023
You may have encountered some kind of bug. In this case, you need to contact support.
Can you share a link to an example file?
@tank666 just figured it out (kind of). Turns out it was less related to the styles I was attempting to move and more where I was trying to move them. Apparently one of the styles wouldn’t allow me to move something beside it. But by juggling the styles around with some trial and error I was able to get things set the way I wanted.
I do think it’s a bug, but it’s no longer blocking me.
IServ_Isik
Got the same bug. It’s definitely not user error. I use Figma on a daily basis since release. It even moves the style to the desired place and then moves it back a second later, lol
Maxim_Siebert
Happens for me pretty consistently still:
Jun-09-2023 15-54-07
Daniel_Cullinan
Same problem for me. This used to work fine, but now it’s hit and miss.
Julia_Shlyapnikova
Same for me. It was not like that before
Joakim_Melkersson
Still broken. Some color styles can be dragged to a new position, others just jump back to where they were. No difference in how these styles are organized or named, it seems completely random.
Stefan_Brigola
Hi all, I already discorvered this a long time ago but now I thought I have to ask. If I want to reorder styles in the list from bottom to top – it´s not possible. It always jumps back to bottom. If I do it the opposite it works, from top to bottom. But if you have lot a lot of styles it´s annoying to do so. Anyone else experienced this?
Gayani_S
  • November 10, 2023
Hey Stefan, thank you for flagging this with us. We’ve escalated this bug internally and the team is working on a fix!
Joseane_Castanheira
Same problem here 😢
Gayani_S
  • March 13, 2024
Hey @Joseane_Castanheira, thank you for flagging this. To be transparent, given that this is a long-standing bug and our team can not consistently reproduce this, so it will not be prioritised at this moment.
However, I’ve forwarded your feedback to the teams.
Thank you,
Gayani
AMV
  • April 6, 2024
I am getting the same exact problem…
Alyssa_Maac1
Bumping this thread because the issue is still here and it’s annoying me out
  • April 11, 2024
Hey @Alyssa_Maac1, sorry to hear that you’re still having trouble with this!
Tank’s solution is still correct, but let me provide some additional context from the team.
Our team confirmed that we’ll always show “Variant properties” at the top of the list and “Component properties” below. So while you can re-order within those sections, it’s not possible to re-order between the two sections.
Does this sound like it’s matching what you’re seeing?
Alyssa_Maac1
Hi @dvaliao that’s not my issue.
It’s just reordering the text styles, sometimes it works, sometimes it doesn’t.
Here’s my issue. I cannot reorder text styles. I’ve been trying to drag it and it keeps on going back to original position.
Animation
  • April 15, 2024
birdio
  • May 29, 2024
I have the same problem: cannot reorder text styles, but interestingly enough, only if pulled towards the top. Somehow dragging and dropping a style works if the new position of the style is below the old one.!
So basically after creating a new Headline text style that ended up at the bottom, I just went a full circle to position the style at the top 😃
Also, I have no issue with reordering color styles, it only happens with text styles.
Karol_Rycio1
I have the same issue. It’s so annoying.
James78
  • June 14, 2024
Having the same issue. Alternatively you can add a new test text style within (Text/test) then reorder. Make sure that the new test folder is at the bottom, reorder folders then delete the test folder.
Elizabeth20
  • March 2, 2025
It’s been 2 years, is there not a fix for this? I have over 200 color styles and they are ordered 900-100 from top to bottom in the styles panel instead of the way they are order in my layers panel 100-900. Why can’t we reorder these? I can’t drag and drop that many styles!
