Hi. I’m Jun, a design system manager in South Korea.
I have a question about components.
Let’s say you have a file A and a file B.
In file A, I created a local component and used the instance on page a,b of A.
Then, if you want to use the local component from A in file B, you can do it in two ways
Option 1. Copy the local component from A and paste it into pages a,b of file B.
Option 2. Move A’s local components to a separate file and use them in B via the library after publishing.
I already know that option 2 is the preferred option, because the component needs to be published from the library so that it can be used in multiple files.
However, Figma doesn’t systematically prevent Option 1, and I can still use the local component from file A in any file.
What I’m curious about is whether the main component and instances are still fully connected, without any loss of integrity, with Option 1. I wonder if a component that is not published as a library becomes a kind of “ghost instance” that is not linked.
