Prototype link broke with nested components randomly
  • September 12, 2024
  • 109 views
Jason_Chang2
Hi, I’m encountering a weird situation that when I used nested component and somehow the prototype links broke(disappeared) randomly so many times and I didn’t do anything.
I made an example to demonstrate what I made in my project.
I created a master component with two properties and make a link to two dropdown menus.
And then I place my main component into my child component and give it a boolean and set to false by default.
And then when I create an instance, it works at that moment.
But when I close Figma or come back to check my design next day(Not change anything)…
The prototype line(instance) just disappeared randomly!!!
And it happened so many times…I don’t know what’s going wrong~
Anyone knows? Thanks in advance!
Gayani_S
  • 2159 replies
  • September 13, 2024
Hey @Jason_Chang2, thank you for reaching out!
Can you let me know if this is happening in the browser, the desktop app or both?
Have you tried to clear your browser cache and your desktop app cache?
You can clear the desktop app cache on a Mac in the Help menu under Troubleshooting.
If you’d prefer to manually clear your cache you can:
  1. Quit the Figma desktop app
  2. Open Terminal.app and enter the following command: rm -rf “$HOME/Library/Application Support/Figma”
  3. Try opening the desktop app again
On Windows you can clear the desktop app cache under the toggle-arrow at the right of the top toolbar under Help > Troubleshooting.
  1. Close the Figma desktop app
  2. Open the Start menu, and paste in this, followed by enter: %APPDATA%\Figma
  3. In the window that opens, delete the Desktop and DesktopProfile folders if they exist
  4. Launch the desktop app again
Could you also try opening your working file and running a Quick Action called “Repair Component Connections”? This command has a similar affect to fetching the most updated version of the main component, without you having to manually change and re-publish the main component and accept updates in subscribed files.
I’ve included some instructions on running the command below.
  1. Open the affected file
  2. From the main dropdown menu in the top left, navigate to the “Quick Actions” search bar.
  3. Search for “Repair Component Connections”
  4. Run this command
Please let me know if this resolved your issue, happy to help out further.
Jason_Chang2
  • September 16, 2024
Hi @Gayani_S ,
Thanks for your reply.
It happened both in the browser and my desktop.
I’ve tried cleared up the cache and run “Repair Component Connections”.
It shows Nothing to repair and the links still gone.
It happened randomly and I need to select each child component to “Reset all changes” even if I didn’t change anything. And there are lots of components… 🥲
I also tried to separate this page to an independent design file to see whether it takes too much memory.(But some pages are small, they happened as well.)
Some of my team members are using New UI3 (beta),some are using the old version, will it be the root cause ?
Thank you~
Gayani_S
  • 2159 replies
  • September 19, 2024
Hey @Jason_Chang2, thanks for the confirmation!
I can confirm that all functionality remains consistent across both the old Figma design and UI3. This should ensure that there will be no disruption in your team’s daily operations, even if some members are using different versions.
I will get you connected with our support team so they can investigate what’s causing this.
Your ticket number is #1127421, for reference. Someone from support will be in touch with you soon.
Please share a direct link to the file with our support team, and invite support-share@figma.com with “can edit” permission so they can look into this further?
Note that users with @figma.com emails on your team do not count towards your billing.
Our support team usually takes up to 24 hours to reply back to emails - tends to be quicker than that in normal circumstances. However, please be aware that we are facing increased contact volume so there might be a delay.
Appreciate your patience in the meantime!
